I am trying to do a temperature sweep on a BJT.
The BJT_NPN device has a "Temp=" parameter to specify the device operating temperature.
When I use the BJT_Model component to define the model for the BJT_NPN transitor, the BJT_Model component has a "Tnom=" parameter to specify the nominal ambient temperature for the device.
Each temperature specifier affects the transistor in a different way.
When doing a temperature sweep, which do I specify as the variable component? Temp in the BJT_NPN transistor, or Tnom in the BJT_Model, or both?
