I need to use some SDD components to define a new component. It is all right with only one SDD. but now I need to use two of them, and I must introduce a relation between them like "_v1(of the 1st SDD)=_v1(of the 2nd SDD)".
Is there a way to do this ??
I have the same issue to define a variable like "XX=_v1(of the 1st SDD)+_v2(of the 2nd SDD)" when there are more than one SDD.
I didn't see anything about this in the help.
Thanks.
P.S. : is there a way to attach files (like shematics) with this kind of mail to make it easier to understand ?
Thanks.
You can't place multiple SDD's on the same schematic page and write equations like this as far as I know. I think you need to put one of the two SDD's into another subcircuit.
Many times it's easier to try to implement it into one single SDD instead so that you don't have to deal with this. Then you can access any voltage easily as you already found out.
No, sorry. This feature was not enabled because of the risk of virus and other mean attachments to be spread using our website. We might revise that decision but for now it's not possible.
