When I simulate a balanced transmission line structure with differential mode or common mode ports, the differential mode and common mode characteristic impedances are calculated. If the transmission lines are asymmetrical then the odd mode and even mode characteristic impedances will be different for each half of the transmission line structure. How can I determine the individual odd mode and even mode characteristic impedances?
