I simulated a cylindrical via in momentum with the following dimensions:
Height= 8mils
Diameter=8mils
Via pad (square)=13.5mils
Metal thickness=1.4mils
Substrate parameters are
GETEK
Dielectric constant=3.83
Loss tangent=0.008
Configuration of the substrate is:
Strip METAL
GETEK dialetric VIA
GROUND
I then simulated in ADS a VIA2 component (with the same dimensions) from the Tlines Microstrip Palette.
The inductance given by momentum was different than the inductance given by the VIA2 component.
Inductance of via (momentum)=58.7pH
Inductance VIA2 =21pH
Why is that?
I would expect them to be the same.
Any clues?
Thanks
Height= 8mils
Diameter=8mils
GETEK
Loss tangent=0.008
Strip METAL
GETEK dialetric VIA
GROUND
Why is that?
Any clues?
Thanks
Momentum may underestimate the low-frequency inductance by about 10% because it assumes current to always flow on the surface of the via, never distributed evenly inside the via as it would be at low frequencies.
The best way to solve your problem would be if you could package up the project as a *.zap file (Archive Project command) and send it to technical support.
