Hi There
I am trying to use variables (defined in Var) in MLine Smart Component, (freq & LElec). An error message flashes up for a fraction of a second before closing.
The smart component is not being designed.
Can I use variables in Smart Components.
If yes any idea on how I can find out what is not working?
If no - why not - this should be very powerful.
Chris
Chris
A variable could be swept using a ParameterSweep - which would be a problem with the Smart Components since they need to be re-designed after a parameter change. That's why the variables are not supported for Smart Components.
