With certain values of mesh (e.g. 20 cells/wavelength) the mesher fails to create a mesh, and the results window shows the error below. How do I compile a defect report for this?
error message:
Simulation / Synthesis Messages
Substrate valid
Mesh generation at 1.26GHz.
ERROR : MomMSHmaker: internal error 11 -- segmentation violation
Status / Summary
------------ Momentum Simulation ---------------
Version: Momentum MomEngine 5.0 (*) 2003C.300 Nov 25 2003
Simulation mode: MW
Design: Alumina_dual_feed_5mm_2mm_ltd_gnd_circular_scaled22
Mesh generation started
--------- Momentum Simulation stopped ----------
error message:
Substrate valid
Status / Summary
Simulation mode: MW
Substrate valid
Mesh generation at 4.5GHz.
