I have a general question about using AEL macro for layout.
I am currenlty using "home made" user-compiled models in S-Parameter simulation.
Basicaly I have 2 elements that have a dll associated for schematic and simulation and I have associated AEL macro for a representation of those elements in layout.
Of course the parameters or those elements are variables that I optimize during simulation.
Now here is my concern, when I create a network that uses sub-networks populated with my elements, I define the variables in the high level schematic. Of course the variables are passed to the sub-networks and the simulation runs just fine.
But on the layer side everything is messed-up :
1. only part of the "drawable" elements are represented in the layout
2. The elements are placed "randomly" on the layout.
Here is a more tangible example:
I have 2 type of elements : gratings and transducers.
Both have a dll for simulation and a AEL macro for layout (they share the same AEL definition of course).
I have a sub-network called Track1 that contain 8 instance of transducers and 4 gratings.
This Track1 sub-network also have variables definition that are passed to the elements grating and transudcer.
I also have a master schematic containing/defining all my variables call D1
D1
â””-- Track1
â””----TransducerWithArtwork (8 instances)
â””----GratingWithArtwork (4 instances)
When I ask to generate the layout (layout>Generate/Update layout) only part of my gratings/transducers are represented....
Any idea ?
PS : If you have read this email up to this point, thank you very much for your patience and sorry for my bad explaination.
D1
â””-- Track1
Any idea ?
I would recommend you to contact EEsof Technical Support to get help figuring out what the problem is in this specific setup/design.
