I noticed that if I set the frequency range from 0.25-110 GHz the Advanced Model Composer uses 7 frequency points for a simple circuit. However, if I select 0-110 GHz only 4 frequencies are used. Could you please advice me what selection you would recommend me to use? Even though the first circuit only has data from 0.25 GHz it simulates fine in a DC bench and the DC data is of importance in my HB simulations later.
Mikael
Mikael
