hello everyone,
i am lerning now ADS,and have a problem.
i have builded a user library, others were good, but there are no description of components, webpage,etc. But in Designkit libray, everything is ok. who knows why?????
yanning
hello everyone,
yanning
There are two formats supported for the record and control files. The new format is using XML which is the recommended way to go. More info can be found in the Design Kit Manual:
http://eesof.tm.agilent.com/docs/adsdoc2003A/dkarch/dkarch043.html#1110471
This document in EEsof Knowledge Center describes how to install your control and record files into ADS in a general way.
ADS : How to create a hierarchy/sub-libraries in the library
http://edasupportweb.soco.agilent.com/cgi-bin/show.pl?id=56081
The format on the control and record files is however the old format. I would recommend you to use the new XML format for the record and cotrol files as described in the Design Kit manual. You can use this document for installation reference.
URL modified by support_admin @ Mar 3 2004
