I am working on a complicated 4-5 level hierarchical simulation with hundreds of pieces using harmonic balance with noise controllers. Those same nodes retain their original name for the "non-noise" portion of the simulation but the data display window should show a node.noise
parameter and it is not present. It appears that in place of the desired nodes to measure noise, it replaces them with other nodes that have _netXXX.noise nomenclature.
We recently upgraded from 2002C and did not encounter the issue with that version.
Lou
Lou
Still it's hard to say what's the problem. I found one bug report that talked about a similar symptom. In that case the problem was caused by having Noise Contributors set to "On" in the HB controller. If you turned off the Noise Contributors then the noise voltages were saved ok. But that problem was supposed to be fixed in 2003C.
It's really hard to say without having the file. Please send the file to EEsof Technical support for examination:
