I have used ADS to make a layout for a PCB board. My problem is when i print the artwork it is not to scale and hence useless.
How can I set ADS to print to scale.
Thank you in advance.
William Thomas
William Thomas
I understand your question that you want to get the printout from your layout with the correct size?
If this is what you want to do, please be sure that at the print window the radio button (at the bottom) "Fit to page" is not selected.
Hope that this has helped
Best regards
Franz
