Hello, sorry if this is not correct place to post this but I could not find anywhere else that would be good.
After installing ADS and using license, there are certain exe's that still do not run. Awc.exe, iccap.exe, libtrans.exe, rfcompiler.exe. When I try to run these I recieve this error:
"The ADS tool has failed to run: Please verify that you are licensed to run this program. Also verify that the install directory is avalaible."
I have license to use ICCAP, so iccap.exe should work, yes? Or is this other problem?
Thank you in adbvance
