I'm trying to compare measured data and ADS simulation. Â The measured data consists S-parameters in Touchstone format and I have data for several identical devices. Â In order to compare measurement to simulation and to capture the natural variation between measurements I would like to plot all the measured files efficiently by using a parameter sweep or something like that. Â I've tried creating an array containing the file names and sweeping an index but I'm running into problems. Â The procedure I'm familier with from ADS loadpull using the list() function doesn't seem to work the same way with string variables. Â I also tried the makearray() function without success. Â Please do you have any advice or an example showing how to do this?
BTW I'm using ADS2005A.
https://edasupportweb.soco.agilent.com/ ... ref=search
