Hello!
I have 2 differential transmissionlines, each with a series capacitor an one shunt capacitor inbetween.
the caps are real components from the murata-lib.
As the connected balun isn't totally identical at its balanced ports, the optimizer calculates different values for the capacitors, but i want them to be euqal.
How can I set up such an optimization?
Thanks 4 help!
Best regards
andreas
Thanks 4 help!
Best regards
andreas
C1
C=X
C2
C=X
Var
X=2 pf opt {1 pf to 100 pf}
If not, Maybe you can put the murata cap inside a subcircuit and use the instance of the subcircuit on the top level and define a variable for the sub-circuit which is optimized.
Some links that may help:
https://edasupportweb.soco.agilent.com/portal/page?_pageid=36,39953&_dad=portal&_schema=PORTAL&itemid=33496&search=optimize%20same&cid=2434&ref=search
If you still have questions, I recommend contacing Technical Support.
Nilesh
