I've tried all the options I can find , but I can't get a Layout Component imported into a schematic to show any layers other than 'cond'. I have some geometries on cond2 that should also be shown in the schematic for clarity.
please make sure to see the desired layers in the layout editor (Momentum). The component contains what you see in Momentum. Any layer not visible in Momentum once you start the model generation will not be in the component.
Please reload the layer file in the schematic editor after the model generation. There is a layer file for schematics and it might get appended by the model generator in case new layers get used.
Please make sure to switch on all layer in the schematic editor to make them visible.
In my case it generally works if I follow this items.
Kind Regards,
Wolfgang
