A transient simulator controls my design. I have a DAC(Data Access Component) to read 4 different variables from the generic MDIF file. DAC settings are as follows.
File = myFile
Type = Generic MDIF
iVar1 = "time"
iVar1 = time
Each varialbe is assigned to one of the DC voltage source with following settings in the voltage source.
Vdc1 = file(DAC1,"Var1")
Vdc2 = file(DAC1,"Var2")
Vdc3 = file(DAC1,"Var3")
Vdc4 = file(DAC1,"Var4")
Hence, I have total of 4 voltages sources. And everything works fine.
Here is my question/problem.
Instead of 4 different sources, I want to create a bundle of the voltage sources, VDC<1:4>.
And I want to assign different variables to each of the instances through above method. However, all of my instances are assigned to only VAR1..
What should I do ? Do I need to change MDIF file ? or some setting in the voltage sources ?
Viral
File = myFile
Type = Generic MDIF
iVar1 = "time"
iVar1 = time
Viral
-Mats
