As per usual, generating Layout from Schematic (in order to do Momentum simulations) is driving me crazy - Ports should be allowed to overlap, after all it's often necessary to have internal ports.
If it's problematic in the code to allow overlaps then at least generate the overlapping items as close as possible to the rest of the layout - I'm tired of having to move them from half-a-lightyear away, where zoom-extents has made everything microscopic; especially as select-and-drag tends to move the connecting lines rather than the components one wants.
Laurens
Laurens
