I'm trying to export many different dataset (specifically S-parameters) to text files through AEL similarly to the way the "Data File Tool" or the "File > Export" of the data display window does. As stated in a previous post, I know that the function de_dftool() pops up the DFTool window but since it’s not documented, I’m not sure if it accepts parameters for an automated process. Neither if there is a function for the data window export function.
Can I use de_dftool() or is there any other way to automate the export process of S-parameters or datasets?
If not, is there anyone who knows the internal structure of a .ds file so I could directly read it and extract the relevant data?
Thanks
R. Labedan
Thanks
R. Labedan
Manual - write_var()
