Hi All,
I'm designing a microwave filter with momentum layout. The filter layout is a derivated CLFltr design, i. e. Coupled Line Filter, created by the Passive Circuit DesignGuide. In order to align the passband to a lower center frequency, I'm employing the command Edit > Scale/Oversize > Scale... However when attempting to scale the structure, a message box with "Cannot scale instances with pins" appears. Can anybody help or does anybody know a workaround? Is it necessary to remove the pins first and how can this be accomplished? I'm new to momentum. Thanks for any help.
Ralf
Ralf
