Hello!
Is it possible to store all parameters of a item (e.g. a "R") placed on a schematic design in a file using AEL commands?
I try get_item_list (which seems not to work with Custom Library Elements, but well for e.g. R's) to get a list of items, but now I don't know how to get all available parameter names and values ...
Any hints?
Best regards,
Martin.
Any hints?
Best regards,
Martin.
I created a small AEL function which extracts all parameters from a given component. You can download the AEL function here:
get_instance_parameters()
The function returns a list which you can process/output in any way you like. Here's a simple example:
