I'd like to optimize using standard component values. The format for a continuous optimization variable is:
C1=4.7 opt{2.7 to 10}
How can I set up the optimization variable to select from a series of discrete values - something like:
C1=4.7 opt{2.7, 3.3, 3.9, 4.7, 5.6, 6.8, 8.2, 10}
What is the correct format for doing this?
Discrete Optimization using data file values
Chipcap - Discrete Valued Parts
Discrete Optimization with DAC
Discrete Valued Parts with Tolerance
Discrete Valued Parts - S2P files
URL's modified by support_admin @ Mar 3 2004
