In the options block for S-parameter simulations there is a check box called "Use S-parameters when possible" (ForceS_Params) under the section Linear Devices. What is the idea behind this parameter and what implications is it not having it checked (the default is to have it checked)?
I am asking this because I found, and reported, a tricky bug in the refnet component that in my particular case requires me to un-check this parameter.
Thanks!
Thanks!
