Hello!
I tried to generate my own S2P files and failes while loading them in ADS (P2D simulation fails).
I then compared them with the ampp2d.p2d example file and found the only difference in the column looking: in the example, all columns are aligned in one "optical" row, while I only use 2 spaced between each colums.
The documentation does not state how the separation must look like.
So my questions are:
- what it the separator (space) ?
- how many separators must be used?
- is the number of digits limites (examples uses 3 after the ".")?
Best regards,
Martin.
Best regards,
Martin.
The number of digits should not be an issue either.
Do you get any error messages, other than that the simulation fails?
I have seen in a few cases where a user had a weird / unprintable character at the end of a S2P file. Notepad etc did not show the character. But everything started to work when we deleted the last linebreak/character in the file.
You could try to debug it by trying to run just portions of the file, adding a few lines at the time until you find the problem.
Please send the file to Technical Support in caase you can't figure out the problem.
