Is it possible to send the actual component parameter value to the dataset?
I'm trying to setup a resistor with a thermal coefficient and I would like to check out if I have done it right. Is it possible to send the actual resistance value to the dataset etc and check it out?
Other=OutVar="R1.R"
Note that the syntax is case sensitive!
Please see this document for more info:
ADS 1.3; OutVar and component values Using the old OutVar syntax will cause problems when running an optimization.
