Yes, The 16700-69407 replacement HDD kit for 16700A and 16700B contains the 36G HDD .
Depending upon what the 16700A/B currently has in it, you may or may not need the bracket and the 50-68 pin SCSI adapter which is in it.
That is, the newer frames which already have a 18GB or 36GB HDD will probably already have the bracket and SCSI adapter while an older frame with a 9 GB HDD or smaller HDD will require it.
