Hello Every one,
I have another big problem in transient simulation. When i save my circuit and simulate it using TRANSIENT simulation, some times, it simulates and then i get the data display window. And When i click the Plot Graph type in the data display window. Automatically a PlotTraces and attributes window comes.
It normally has the ports which i defined, and then when i click on either Input1 or Input2, it shows the graph.
BUT!!! sometimes the PlotTraces and attributes does not show any variables to plot to (for example Input, Output etc)
Please help
Please help
(Menu: Simulate > Simulation Setup...)
The Data Display plots values from datasets. The default dataset that it reads the values from is controlled in the drop own list in the upper left corner of the window. Make sure you pick the correct dataset name, i.e. the name of the dataset that you simulated to.
