In the visualisation package with Momentum is the current density units Amps/meter or Amps/meter^2.
I know it says in the Momentum help file, chapter 13, that it's Amps/meter, however, I was questioning whether this was correct because of it being a density. I suppose it is Amps/meter because of it being surface current with no thickness.
Version: ADS 2004A
O/S: MS WinXP
Version: ADS 2004A
O/S: MS WinXP
