I'm trying to simulate a discrete balun according to an application note of an IC-maker (CC2420) by means of using the balanced port implemented in Genesys.
The balanced port impedance of the IC is (60-j164) ohm and should be matched to a 50 ohm (unbalanced) antenna.
By using the given values of the discrete components (for the balun) in combination with the balanced port the scattering parameter look very bad. In contrast they look very good if I adjust the balanced port impedance (of Genesys) to only 'half' of the given unbalanced IC-impedance (Re/2, Im/2).
Can anybody comment on my observation?
Thanks and regards,
Achim
Thanks and regards,
Achim
Questions regarding the operation of GENESYS should be posted at the Product Questions forum. I have moved this thread for you. It will be easier for them to help if you attach the workspace, so you might go ahead and do that.
Hopefully someone there can help.
Clear skies and high Q
