Hallo,
I create a mfilter synthesis and then a active filter synthesis. Both synthesis create a goal item. In the active goal, only the parts used in the active design (lp analysis unchecked) appear which is as expected. If I delete all variables and click on get tuned variables, it considers the variables of the two designs. However the mfilter analysis is still unchecked. is it a bug or is there a way to avoid it ?
best regards
marc
best regards
marc
I don't know what you're asking. It's not a bug. If you have multiple analyses you have to determine which ones the optimization executes. When you run a synthesis with goals we automatically create a goal for that synthesis. If you want to manually change the optimization that's your option.
Mark
