I am fairly new to Genesys and am having an issue with transient analysis.
The issue is that whenever I attempt a transient analysis the Transient analysis in the workspace tree remains red and still has the [Old Data] text. The data is also not created, so I assume that the simulation is not running at all. Prior to running the simulation I press the calculate button, so that is not the issue.
The workspace that I am using is the example BRIDGE_T. I am following the instructions as given in the genesys help files. I am running Genesys 2009.04.
Thank you for any help you can provide.
