Does Genesys have a function that reports the index or frequency at which a max or min occurs? At a previous job I used ADS, and it has one called find_index that was pretty useful. Not positive of the ADS function name. Thank you.
' Filter1_Analysis_Data is the name of data being 'written to. ' S11 has been defined as S[1,1] in the dataset using("Filter1_Analysis_Data") theIndexForMinS11 = [abs(S11)@min(abs(S11))] scalarIndex = theIndexForMinS11[1] minFreq = F[scalarIndex]
Have you considered using something like:
