Is there a way to fix the analysis parameters so they are not changed if a synthesis is modified? I'd like to be able to view the results of different syntheses across a broad band, but a change in the synthesis tool forces the analysis to revert to frequencies around the synthesis settings.
Thanks.
Thanks.
Add another Analysis to your workspace and use it to analyze the "broad band" behavior of the same synthesis circuit.
You should also close the synthesis-owned graph and create a new one, via right-click copy / paste in the workspace tree. Then change the new graph's Default Dataset to use your broad band analysis, instead of the synthesis'.
