The actual tunable parameter of an inductor is L and a capacitor's is C. The default variable-name listing in the Tune Window is of the form part.param, which would be L1.L, L2.L, etc.
If the part name is currently omitted from the tune list, use the Item Menu button at the top of the Tune Window to adjust the parameter display, as shown in the attached image (which shows all 3 display settings).
Hmmm... The default value of the setting has been changed in 2008.01 (to hide the parameter prefixes). I'm in the process of verifying that the change was intentional.
