I'm noticing that some of the supplied Genesys models -- such as those for the Coilcraft inductors -- use a standard 2 pin inductor symbol but reference a 2 port S parameter data file.
How does Genesys "know" where to tie the reference for the 2 port S parameter data to? Presumably it goes to ground?
The inductor says it uses model TWO, but looking up the on-line help for TWO shows three terminal devices.
---Joel Kolstad
---Joel Kolstad
Yes, I guess you could say it references to ground. That third port is autogrounded in the symbol.
Mark
