How to display P1dB performance of cascade vs. frequency sweep in Spectrasys ?
Also what would be good way to simulate reciprocical mixing effect in Receiver? I have added sources for LO with phase noise mask specified in external file and I have added blocker to the input but results are erronous after that. Thank you in advance.
First, get the measurement working how you want in a SINGLE frequency simulation.
Second, make the frequencies an equation variable.
Third, add a parameter sweep where you sweep the frequency variable and the SPECTRASYS simulation.
Fourth, change your output to look at the sweep, not the SPECTRASYS simulation
That's all there is to it!
Rob Lefebvre
