Yes, in older versions of GENESYS this was done if you wanted to use grounded collector configuration, etc.
Good news; it's no longer necessary to do this in GENESYS. Simply ground the terminal you wish to be grounded, and place a port at the other terminal from where you desire the measurement. GENESYS will detect what has been done and automatically make the appropriate conversion.
etc.
