Hi, Everybody,
(Genesys 2006.04).
Open up examples\\Spectrasys\\VSWR Tester, my favorite example. Run the simulation, look at the 450 MHz IF output spectrum, and zoom into the area around 450 MHz, the IF1.
Hover the mouse over the 450 MHz IF signal, and you get the information about the path that generated that signal. But hover the mouse over the spur at 380 MHz, and no such path is displayed. Am I doing something wrong?
Al
(Genesys 2006.04).
Al
The problem is that there are two spectra overlapping each other and it's tough to exactly click the right spot. A simpler approach is to click the point to generate a marker and with markers on the right and you'll see all the markers (you can mouse-over the marker signage to expand the entire path if the marker is clipped).
Mark
