Is it possible to use SpectraSys to model direct conversion systems (Zero IF)? Actually, can SpectraSys understand Complex Baseband signals at all?
I have tried but I seem to fail how to configure the mixers. In a TX test setup I have two sources with 0/90 deg phase shift and have entered a reference clock name to make sure they are "synched". My LO's are 90 deg apart (of course). Still I get only like 15 dB image reject.
Our company is evaluating Spectrasys but maybe it is not the tool we should use for this?
Kindly, CG
Kindly, CG
Please contact tech support and they can put me in touch with you to discuss this.
