Is there a script command to open the item(controller etc.) property?
I attempt to make a template with script buttons.
Now, I want to open Optimization property.
OpenWindow() is not reasonable.
I know it is opened by to select it and "result = Application.Menu.Edit.Properties.Execute()".
However, I can not select item well with script.
Does "Selected" variable of Optimization(Items?) property not work?
I could not select Item though I set Selected variable to 1.
Is there a method of enabling item to be selected?
Please give me some advices.
Kazuhito Kiyama
Kazuhito Kiyama
