Hi
I'm not sure if the attached bug3.wsx file has a bug but can you please analyse it and compare the following conditions:
Analyse it with no changes and store the results.
Then analyse it again but remove the series 0.0001 Ohm resistor R2 by port 3 and bypass it with a shorting wire. This should not make any realistic change but I get a vastly different result.
I also get similar problems if I remove and bypass R1. i.e. the deep notch on the S31 RX graph is corrupted unless R2 or R1 are removed and bypassed.
I tried rebuilding the circuit from scratch and the new version behaves correctly. So does this bug3.wsx have a strange problem? (or maybe I haven't woken up yet on Monday and I've made a silly error somewhere )
Thanks.
Thanks.
This should show infinite loss due to the perfect ground. So something horrible has happened with the netlist on this wsx file.
I created this wsx file by cut and pasting some of the network from another wsx file so maybe something has got corrupted during this process?
