using a variable for port impedance in Genesys
In general, equation variables are very easy to implement
in Genesys. For example, you can open the equations page
and enter
var1=56
then use that variable to drive a component by entering
var1 instead of the component value. (you can enter var1
for multiple components, and they will then be driven by the
same variable- that's called gang tuning)
You can make the variable tunable by changing it to var1=?56
This can also be done for input / output ports to make the impedance
a variable. What you'll need to make sure to do is enter in the
input / output port =var1
The equal sign tells Genesys to get the variable from the equations page.
and enter
var1=56
