To export data tables to csv files in Spectrasys, it seems that all the measurements need to exist. in other words, if you are trying to export a table with hidden measurements that don't exist, saving the file will fail silently, with no error messages.
Dave
Dave
However, I'd like to verify something: If the measurement is NOT hidden, you do get an error, correct?
Also, I think the actual bug is that hidden measurements should not be exported.
