I'm not getting consistent P1dB predictions from Spectrasys for a simple cascade analysis. It is depending upon source input power.
If I use the example file from Eagleware Spectrasys titled "System Input P1dB", I get the following results:
-50 dBm input gives IP1dB of -20.557 (default)
-70 dBm input gives IP1dB of -24.073 ???
In the standard interpretation, I don't believe P1dB should change as a function of input power.
In 2008.01 the answer is -22.397 dBm.
Thanks for the feedback.
