I am making a strip line which is 25 um wide. When I add a ground to that it looks huge (75mm) on the Layout window. How can I make it small? So that it matches with the rest of the circuit.
To change an existing ground, double-click it on the layout, click Change Footprint, and pick "GROUND, BOTTOM, 10mil" or 25mil from SAMPLE.LIB.
To set all future grounds, double-click the Layout, click the Associations tab, and Change GND, which is the first item in the list. Then Save the associations table for future use.
