I have Agilent3070 using window 2000 and version of BT-Basic is 3070 05.31 pa 0304 WN.
And I also have server with UBUNTU as the OS in separate place.
On Window2000 able to map to server but why BT-Basic cannot link to the server with condition as below,
Assume T drive as server,
In BT-Basic, I type
msi'/T=' ,then enter (no warning or message on display)
msi$ ,then enter (in the BT-Basic will show message as 'The system could not get the current directory'
So any body know how to solve this problem and what should I do for it?
In BT-Basic, I type
Are you able to see the contents of the Unbutu directories within the "T" drive using Windows Explorer?
Are you able to create a new file (any file, e.g. text file) or create a new folder within the "T" drive using Windows Explorer?
