Hi there,
did anyone ever try to run the 3070-SW (either for the Test-System or for the Development-Station) on a virtual machine software such as Virtual-PC or VirtualBox?
I´m considering this possibility because we are planning to switch over from UNIX to PC next year and the first test installations generate more problems than expected: The X-Server-Software conflicts with our more efficient Reflection-X-Software and lots of System-Settings are changed without permission. So it could be a smart solution if we could run the 3070-SW on a virtual machine.
Any experiences?
Any experiences?
first point is that we are talking about PC's here and not UX. As you know, currently UX systems are multi user and support multiple logins - PC's do not.
That is why the pC software is available as development to be installed on users laptops and PC's for offline work. You can map and/or share drives if you need to edit files on test systems.
If you want to log onto a test system - the standard XP tools work fine, we have been able to do remote debug, but remote access tools on XP require just one user logged in - you cannot log in transparent to the testing process.
We also use a Agilent remote support tool called webex on PC's which enables the user to share and allow us to take control of the test system for application queries and support - this works really very well in making fastest support possible.
I moved from UX about 5 years ago and i would never consider to go back - whatever help you need please work with Agilent to resolve.\
thanks, Jon
