16900 uses a crystal oscillator that has a frequency stability of +/-100ppm. All internal clocks are derived from that oscillator.
If higher stability is necessary, an external 10MHz precision reference can be used by connecting to the external clock input on the back of the LA frame.
In STATE mode we use the customer’s externally provided clock to the LA module input.
