This feature has been on the 5000 and 6000 Series, but has not been well explained.
If you load a file such as the one I have attached (notice it is a txt), it acts as though you manually entered each label in the file. If a label has lower case characters, they are converted to upper case. If a label is too long, it is truncated. 6 characters is the maximum.
Save list in your USB thumb drive as a txt file then download it using the file explorer feature of the 5000 and 6000 Series oscilloscope.
Here's how you download it:
Press the following buttons from the front panel of the oscilloscope:
"Utility" --> "File Explorer" --> "Location (find labelList.txt)" --> Load File
Once you have downloaded it go see them in: "Label" --> "Library"
