I make a simple amplifier circuit using transistor with S parameters file.
Am I right if I tune others elements(resistor...) to find working point of the circuit. Because S parameters file of transistor was calculated in not 0 frequency, but for bias circuit work with O Hz
Other, Can I do automatic optimization in both DC(DC currents, voltage) and AC(Sparameters) at the same time? Genesys seems do not work when I put an ammeter(Current probe) into circuit which using S parameters in optimize.
Any helps!
Any helps!
