Does anyone knows if a user model can be defined in mil's and not in mm ?
While trying to transfer a schmatic to a user model , I had to manually change the length values from mils to mm , because if wasn't possible to change the unit in the user model schematic to mils .
To be more exact , in the global definitions ( i.e tools>options menu) the units are mils , but a microstip that was present in the schem , was in mm and could not be changed to mils.
On top of that , when completing the units translation , and viewing the behavior of a schem implanted with the model vs the original schem , the results were not the same !!!!
Are there any more limitations on a user model ?
Is it possible to use in a user model elements that are themself defined in a diffirent user model ?
As I understand , when you make a user define(footprint editor), you can set the unit as follow:
Double click on the layout properties after call Tools/Footprint editor/ New footprint and change the units in General tab /Units.
After you set the units and make a footprint, you can call that footprint in your layout with exactly in size.
Also. the way to set the units in Layout is the same as the way in setting units in footprint editor. I mean doulble click on Layout properties/General tab/Units....
Good luck,
Vo
